tsfelt
- March 5, 2011
- Ga
- 97 2dr Sport 4x4
Ok Guys,
Found the site a few weeks ago and love it. I just hope you aren't gonna tell me I bought a lemon.
For my sons 1st car, I found a 1997 Explorer, 150k, in relatively good shape. Only problem is no reverse. On the drive over here to show it to me, the guy lost all fwd gears. To make a long story short, I got a great deal on it.....but now I'm wondering.
I have fwd/rev in 4wd Lo, but nothing in 2hi (auto) or 4 Hi. After spending a few hours researching (mostly on this forum) I am not convinced the transfer case is bad, but the shift motor is the culprit. Here lies the problem.
The transfer case motor rebuild on this forum - my apologies, I forget the posters name - are excellent.....for a 7 pin motor rebuild. Looked great until I crawled underneath and found a 14 pin connector, with what I believe are the front & rear speed sensors, all wired to the same plug to the harness. I believe (based on the case tag info) that this is a Borg-Warner 4405-08 model transfer case
No problem.....except that no one lists the 14 pin connector shift motor!
7 pin motors can be had for $58-85 online or at the major chains all day long. Is the 14 pin connector that rare (i.e., is this model so bad they quit making parts for it??)
And by the way, Ford apparently calls it an "encoder motor".
As of now, I'm going to keep searching salvage yards, hopefully one can be found relatively close to me.
I still have to test the motor tonight, and verify that manually shifting the transfer case to 2H will indeed make it work. If I can't get it into 2H manually, this whole post may be useless, and I'll be shopping for a whole new assembly.
Opinions, suggestions, tips, recommendations are welcome!
Thanks,
Tim
Thanks,
Tim
