allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
Not too far back in time, I installed some cheap LED lights in the old fog light positions. One of the cheap LED lamps quit working.
So I had some vintage (25 yo) lights sometimes referred to as "cat eye" lights.
Monday late in the day I was tying to connect one to the truck wiring. It would not turn on. I then plugged the good LED driving light back in and it would not turn on. I may have blown a fuse. This morning before arriving at work, I thought that it might not be a bad idea to check polarization, attached the white wire to positive and the black wire to negative. the cat eye came on. I decided to get out the DVOM and see if the case of the cat eye and the black wire had continuity. Yep!, the case of the light is grounded. To confirm this, with the light mounted to the bumper, negative wire dangling, I put + power to the white wire and the light came on.
Just two weeks ago or less, I was reading Jamie's light bar thread and though that it was interesting that the relay is switched on by connecting the ground wire to ground. Something tells me that I won't be able to use this stock light circuit with the old cat eyes. It seems as though I need to add a relay and switch to control these add on lights that the cases are grounded. Any thoughts etc? The camera flash makes the light appear to be on in the picture.
