- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
/\ Did Ford use the E7 male torx head on the 5.0 studs ? Like on the 4.0's..... not a common socket to have.... just a heads up...
No issue there, they have normal good bolts, it's just the old age and corrosion that locks up some bolts. The heater hose pipe can be corroded also, or the large fitting connection not let go. We've seen more of that now that most of these are 20-30 years old(the modern 302's).
