SuperGordo
- May 28, 2009
- Las Vegas, NV
- 2022 Explorer ST
So far my initial running of the Ex project is good. Had to seal up a tiny coolant leak coming from a plug in the water neck. I have no oil leaks, no power steering leaks, no tranny leaks. That's good news. Found a burn hole in the vacuum line that goes from the vacuum tank to the firewall. Repaired that, all interior HVAC controls are working properly. Need to get the interior back together asap. Then need to get some fresh tires on the wheels, then a good road test. We are much closer to the end.
