CynthiaK
Who many miles on your Ex's OHV engine?
My guess is your leak is probably the Timing Cover Gasket - a weak link the OHV
The first time this showed up on my Ex was at 13 years, 165,000 Miles.
The coolant system was very well maintained - but eventually the service life of the part is reached.
The timing cover gasket is super thin AND has A LOT of WEIGHT on it = timing cover, water pump, fan clutch and fan.
Highly suggest that you use the original green Teflon coated OEM timing cover gasket, available off of Ebay (part number in linked write ups).
Also, set aside a couple of days - it's all in the write-ups - especially the 2nd one
Link 1:
Removing timing cover on 4.0 OHV
Link 2:
4.0 OHV Timing Cover & Gasket Issues
Hope that helps and good luck!
