/Begin_SoapBox
I am not one who replies to dead threads, but I need to chime in to save anyone else that reads this and is considering a swap of this, um, degree..
First...While I will always have an affection for the OHV, it is not without it's flaws. The bottom end is good, yes, but the headaches of maintaining one and looking out for tale-tale cooling issues can be overwhelming to say the least. Work horse it is...race horse it is not.
The SOHC is leaps and bounds better overall vs the OHV. And yes, this is even with the timing components that fail. It's based off the OHV, has more power and torque in the same range, and is so much smoother. And guess what, I just did a complete timing job on a SOHC for the first time. It's not that bad guys. But for the original poster, let me throw this out there (hypothetically)
Option 1 - Swapping in a good OHV
Engine Cost - $250 (roughly)
PCM - $50
Wiring harness - $50
reprogram PATS - $75
Reworked exhaust - $150
Fluids, gaskets, shop supplies, misc - $200
engine hoist - $150
Rough Total = $925
And thats the basics. Now..
Option 2 - Repairing SOHC
Timing Components - $280
Timing Cam Tools (tool loaner program) - $0.00
Rough Total = $480
So for a tad under $450 less, you get to keep your original motor and not have to modify anything else in the vehicle, which will always help with reliability. Plus, you install the upgraded timing components and guess what, they dont fail. Again, Im sure the OP has either already completed his project and didnt say anything, got discouraged, or disappeared, but alas, there it is. And trust me, a novice can time these motors with the proper tools. It's not difficult at all. I love my SOHC and my OHV both, but the SOHC will win everytime when it comes to durability, longetivity, reliability, and endurence.
As far as PATS, there is no bypass for it. You can do two things with PATS:
1) Reprogram it with the proper tools
2) Send the PCM off to be modified to delete PATS
There is no way to modify the wiring to make PATS behave in a way you want. If there is, please PM me, I want to know.
And message centers...while yes, they were only offered on higher trim packages (eddie bauer, limiteds, some mounties) the motor in which they reside didnt matter nor was exclusive to the message centers. They could be had with the OHV, SOHC, and 5.0. it was just a matter if the wiring for it was in place or not. Even non-MC pcm's output the DOL signal (Fuel Flow Output) on a pin with no wire.
Anyway, to those who read this thread to its end, please read this post and consider whether or not you really wanna do this head ache. Thanks for listening
/End_SoapBox
