OL Crony
- April 19, 2001
- Oshkosh, Wisconsin
- 1992 Eddie Bauer Edition
This problem arose a couple of weeks ago and was intermittent, now it seems to be more permanent.
I have no acceleration - LITERALLY - I cannot drive my truck much over an idle. When I step on the gas it must only be very light otherwise if I depress the pedal too much, I get a series of different reactions, but the most common is that it almost dies, give a hurky jerky action and does so until I let up on the pedal. The other day, just out of frustration, I floored the pedal, no difference, except that when I let up on the pedal - backfire. The least common reaction is that I have no acceleration but with out the jerky motion. I could have it floored and cannot get anywhere. During all of this, my check engine lite does not come on. when the truck is in park, i can step on the gas all i want and it works just great, i does this when i want to drive down the street.
The mechanix at two different garages (one of those garages being the local ford dealership ) say that the computer is not reading out any error codes. One mechanic suspected that I got some bad gas but his test said that was not the case. His volume and pressure test also fell within specs. The plugs and wires were checked those passed inspection. I seem to be getting good exhaust - is there a such a thing as an exhaust pressure test, i saw the one mechanic just put his hand back there and rule out a plugged converter. I recently replaced the air filter and disconnected the battery to no avail.
Any ideas that you have would be very appreciated. Idling my truck down the street to work and back is gettin old. Thanks again.
az
az
