2 piece vs 1 pieces ball joint | Ford Explorer Forums
brownbagg
grand bay, al
96 xlt
when you switch the right side from 2 piece to 1 piece upper ball joint. where do you get the caster adjument bolt.
why cant you use a similar one to the driver side at the upper control arm pivot? It uses an eccentric cam does it not?
Apparently you can get some caster adjustment with the camber ajusters. But yea, you'll lose the main caster adjustment bolt.
