Cosmotime
- March 18, 2007
- Denver, Colorado
- 2000 Eddie Bauer
Is there is simple method to remedy a driver's side door hinge that makes a snapping sound when you open or close the door?
I scanned the postings but didn't see any - forgive me if I overlooked it.
The culpurt is the round rubber bumper on the bottom hinge that is designed to hold the door open. The hinge has a spring loaded flat stricker plate. The rubber bumper has flattened on several sides and if a flat side is facing the stricker it makes a terrific metalic "snap."
The dealer said that they would have to remove the door and replace the hinges - a procedure that they wouldn't necessarly recommend due to risk of the door not fitting as tightly as it does now.
Thanks,
Cosmotime
Denver, CO.
(new member as of today)
Thanks,
Cosmotime
Denver, CO.
