Ignition Switch Terminal on Alternator
I have replaced a alternator and a battery only to discover the issue appears to have been a intermittent connection from the ignition to the alternator I terminal..
Jumpering 12 volts from the A terminal the regulator turns on the field without any issues now..(except i have to remove the neg lead on the battery when overnight or when i park as this turns on the field ALL the time draining the battery, i will have to find switched 12volts to jumper to the I terminal)
The symptoms were cold start no charging evidence by the battery gauge and removing the negative lead off the battery that would kill the motor. not to mention the lack of increase in any voltage using a meter when the motor was on and reved..
at times the light would go out and the battery gauge would show a increase in voltage, and removing the negative lead on the battery the motor would still run.
So what these guys are saying about the alternator light being the same circuit can cause your alternator NOT to turn on is FACT. As per the new alternator documentation the I lead MUST have at least 1V on it before the regulator will turn on the field...
My bulb was good, but I think there is a connection problem on the left side of the instrument panel as i have other lights out there now, i had measured > 1 volt (light on) on this terminal when it was failing and over 4V when it was working(light out).. so perhaps 1 Volt just isn't enough.. and the way filament bulbs go bad perhaps it changed resistance or some such nonsense putting the terminal voltage at the hairy edge of the regulator's turn on voltage.. not really sure.. but giving it 12volts turns it on for certain, and the manufacture of the new alternator shows that terminal switched 12volts.. so jumper that puppy before you spend any money..
Here is a good link to a schematic for the 2000 ford explorer charging circuit that shows the bulb and a resister in parallel with the bulb..
http://www.justanswer.com/ford/2m7ml-several-all-main-concern-right-now.html
the little schematic that came with the new alternator shows switched 12volts going to the same terminal that the schematic shows the bulb being connected to..
The idea the engineer who designed this circuit is that 12v switched thru the bulb and resister would drop voltage over the bulb turning it on and leaving enough voltage to drop over the regulator terminal to turn it on. then when the alternator put out some current the regulator must change the resistance on that I terminal and the voltage would rise on the other side of the bulb turning it off..
Since my dash has a battery gauge i don't understand why the engineer didn't just switch 12v right to this terminal.. but he or she didn't. and now a lot of older vehicles have this problem where the alternator doesn't ever turn on..
So i am off to find some switched 12volts so i don't have to keep opening the hood every-time i park the vehicle.. as i refuse to tear apart the dash for this problem.. just very very frustrated i spent so much money for such a poor design..
thought this might help others..
jumper that I terminal over before you buy a new alternator or battery for your problems and i will feel better ..
update.. found a engineering link on this 4g regulator that says to make sure you put a 60 ohm bulb in series with the I connector... to protect the resistor inside the 4g regulator..
cheers!
JahzWolf
