andrew 2000 XLT V8
- August 9, 2022
- Everett Wa
- 2000 Explorer XLT 5.0 V8
This issue just started today I went to start my truck and it wasn’t cranking at all but I was getting a loud whirring/ grinding sound from the starter area when I got home from work I removed the window on the bottom of the bell housing and inspected the teeth on the flywheel and everything looks normal no broken or worn teeth. I had someone attempt to start it while watching the flywheel and it would whirr/ grind and then the flywheel would jump and turn a little it starts eventually if I keep trying but it has been getting longer and longer throughout the day to get it to start just got sure if this could be an issue with the starter or starter solenoid or flywheel or what. Also the starter was replaced 7-8 months ago last may thanks for any hints/ ideas about what it may be
