MatthewH12
- January 17, 2008
- Middletown, DE
- '00 Explorer Limtd V8 AWD
I noticed a few other recent issues (I hope this is the last, heh...)
The rear wiper has a new wiper blade installed, but 95% of the time, when you turn the switch you hear a "Thump Thump", so I know the motor works, but it doesn't swipe the window. Other times it will. I'm thinking the wiper blade is getting stuck in the grove between the window & door, and i'm hoping its an easy fix. I did notice the arm, where it comes through the door is not coming out straight, but at a slight angle (it does "push" back to the proper location), so Im wondering if a support screw has come loose?
I also noticed the radio (it's the MACH audio system (AM/FM/Cass/In Dash CD w/ 6Disc Changer in arm rest) is beginning to experience the "Fade" issue, im hoping this is also an easy fix. I read on ebay there are people who will replace the display board for like $65.
Also, how do I check for the orange recall thing in the engine, im not sure what it's called. I saw an orange circular device with a wire plugged into the top of it, that looked like the pictures but I want to be sure.
Having just bought it used and being more technologically inclined then I am mechanically, I am hoping theres easy fixes to these issues that dont cost a lot of money, as I'm beginning to think I bought a "bad" used Explorer.
Thanks for any help you can offer!
EDIT: I am thinking about doing this for the radio:
http://home.comcast.net/~pioneer_dualmedia/index.html
Anybody had any problems with them?
--Matt
--Matt
