2001 Explorer won't idle | Ford Explorer Forums - Serious Explorations
DucksRule
Portland, OR
2001 EB
My Explorer will start when I turn the key, but won't hold an idle. The problem has gotten progressively worse, as at first I could hold the accelerator down until the engine warmed up, and eventually the idle would kick in. Now, I can drive it if I use the brake to slow and the accelerator to hold RPM's, but the engine won't idle on its own.
Any suggestions? I'm guessing it's a sensor, but hoping there's a mechanical fix.
Thanks in advance.
it could be the air motor, mine went bad and it idled high 89$ fixed it
Thanks for the reply
The dealer replaced the solenoid yesterday. I probably got hosed, but at least it fixed the problem.
DR
