2002 Limited No start | Ford Explorer Forums
Tyson128
Catskill Mountains New York
02 XLT, 95 LTD 98Mounty
I've got a Limited with 140,000 that doesn't start after changing the fuel pump.
It still has low fuel pressure from the fuel valve.
It has a new starter and fuel pump still doesn't start.
Battery's new, as is ignition coil.
Anything suggestions?
Thanks
check your inertia switch... should be under the dash on the passenger side. its a two wire plug with a button on the top. if its not depressed then that is most likely your problem... if you can see a red line (painted on the button) then the switch was tripped and there is no power going to the fp. make sure its depressed and try to start it
a lot of times when a fuel pump is going out it puts a lot of stress on the fp relay, if you are not getting any activity from the pump (no fp prime when you turn your ignition on) you should check output power from the relay.
check to see of you have power going into the relay
if you do then check output. if there is no output then thats your problem
if you dont have power going to the relay you need to find out why... trace the correct wiring.
