Tylers02
- November 24, 2008
- Overland Park, KS
- 2002 Limited
the mirrors bolt right up but the tails are a little tricky. You need the mounting screws along with the grommets that the pins clip into off a 4th gen. Also you need the top socket which needs to be wired to the brown and black wire on the bottom socket and you need the 4th gen reverse light socket and plug(which needs to be rewired) as its differant. I bought mine used off ebay which came with the bulbs, sockets, and wires which made it easy for me but I still need the grommets off a 4th gen as I just rigged the old one to work for now. Once I get the grommets I will do a write up.
