allmyEXes
- February 6, 2016
- No. Alabama USA
- 1997 Blue Ex 4.0 SOHC
- Callsign
- KAGG 3611 (CB)
I'm trying to find a fuel pump relay wiring diagram to find the certain color wire to unpin the ground "trigger" wire to wire straight to ground so the pump will run continuous with the key on. Or, can I unplug the inertia switch connector and put power to the pink wire with the black stripe to run the pump without involving the key? I can have the battery ground wire hooked up then use a long test lead from the battery positive to pink/black wire. Any ST people on today? I will want to do this Sunday morning. Thanks for any info. Greg
