alpha141
- September 2, 2011
- 2002 XLT 4x4 Explorer 4.6
Hi Guys,
Im new to the explorers and this one has been giving me a few headaches.... started running rough a short time after I got it, error codes were miss fire cyl 8 and random miss fire.
I have changed all the spark plugs, the coil on cyl 8 was failing so that got replaced as well. ran really good for a couple of days then started to miss fire again, cyl 5 this time. I changed that coil but it is getting worse but no error codes anymore. The miss fire is really bad under load. There is also a new problem thats just started too, driving along an the dash will do a warning beep every so often, at night I could see a VERY quick flash of the charge light, also when the engine is has been idling for a couple of minutes it will sometimes just completely cut out, also a new problem.
I am sure there has to be a common cause, but buggered if I know... any help would be greatly appreciated.
