LMHmedchem
- October 28, 2011
- 2002 Explorer XLT v8
Hello,
I am in the middle of changing out the power steering system on my 2002 v8. I have the pump out, I have the oil filter adapter off ( I am replacing the gasket), I have the power steering cooler off, I have all the hoses off of the rack, and I have the outer tie rod ends removed. I have the 2 bolts removed from the PS rack frame bracket and I have the steering knuckle detached with the steering wheel tied off. The rack is just floating around in there now and I just can't figure how to get it out of there.
I saw a video for an earlier model and they slid the rack to the passengers side and then could work the drivers side over the frame and out the front from underneath. That doesn't work, or at least I can't figure out how. I can't get it out the bottom either. It looks like if I took off the front of the drivers side lower control arm I might be able to get it out that way but I'm not even sure how to do that. I don't have a socket that is large enough to fit over the nut. I think the largest I have is 24mm and that isn't close.
Do I need to take of the front of the driver side lower control arm?
If so, what size socket do I need?
Can I remove the front bolt from the lower control arm with the arm supported by a jack or do I need a spring compressor, etc?
Won't the back bolt be damaged if the front drops down too far?
I don't have air tools and I don't have a garage, so I am doing this in my driveway with a jack and jack stands.
LMHmedchem
LMHmedchem
