2003 4.0L timing chain balance shaft question
gotobob
Orlando, FL
2003 Explorer RWD XLT
Hi, I'm new to the forum.
I'm presently replacing all the timing chains and guides in my 03 Explorer 4.0L SOHC
Many youtube videos mention that the balance shaft timing chain assembly needs to be working correctly if you have a 4 wheel drive Explorer and say it's not needed for the 2 wheel drive but fail to say you can disconnect it if your engine has one if your vehicle is 2 wheel drive.
Well, I've opened my engines front timing chain cover and even though it's a factory rear wheel drive the motor has a balance shaft timing chain guide assembly.
My question is, can I just remove the chain and not use it since I don't have 4 wheel drive?
Because that would save much time and expense since to change it I would need to remove the upper oil pan to change the guide and that's a lot of work.
Thanks for your help
Bob
donalds
Location
Stem
Nc
1999 ford explorer sohc
Yes you can remove it use a flat blade screwdriver and just pop a link off
Lots of members have removed it with no problems even with 4wd
And welcome to the forum
  • Like
Reactions: imp
gotobob
Orlando, FL
Thanks donalds for the quick reply.
I was just about to edit my post as I realized this is more of an introduction section and also found the correct area and re-posted my question there.
That's interesting that some 4wd members disconnected it and it makes no difference!
  • Like
Reactions: imp
donalds
Location
Stem
Nc
We don't know why but it works lol
Mike65
Location
In my garage working on one of our vehicles.
Toms River, NJ / Horsepasture, Virginia.
00 Ranger 4x4, 99 Sport.
Welcome.
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@gotobob
It HAS to make some kind of difference, though maybe small and not pronounced. Ford does not throw away dough on "Engineering abortions" unless the least-senior guys are doing final design (doubtful).
"All V6 engines— regardless of the V-angle between the cylinder banks— are subject to a primary imbalance caused by each bank consisting of an inline-three engine, due to the odd number of cylinders in each bank. Straight-six engines and flat-six engines do not experience this imbalance. To reduce the vibrations caused by this imbalance, some V6 engines use counterweights on the crankshaft and/or a counter-rotating balance shaft."
See: V6 engine - Wikipedia
Many here have removed their balance shafts altogether from both 2WD and 4X4 vehicle engines, claiming "no difference felt", which of course is subject to question. Vibrational life-expectancy for the engine would be my guess for use of the jiggle-shafts. Personally, I just might remove mine for the hell of it! imp
gotobob
Orlando, FL
Thanks for the welcoming posts guys
So my guess is Ford (in those years anyways) built all the 4L engines with balance shaft regardless if it was going in a 2wd.
Probably easier to do that (manufacturing wise) then to have separated engine lots for 4wd and another for 2wd
  • Like
Reactions: imp
1 2003 4.0 SOHC Timing Chain Engine Noise Stock 2002 - 2005 Explorers 2
K 2003 explorer timing chain saga Stock 2002 - 2005 Explorers 25
V 2003 4.0 SOHC Explorer problem - timing chain(s)? Stock 2002 - 2005 Explorers 1
N 2003 Explorer, 4.0 Engine Rattle (Timing Chain issue?) Stock 2002 - 2005 Explorers 1
B 2003 Explorer Eddie Bauer 4.0l SOHC Timing chain cover gasket change Stock 2002 - 2005 Explorers 3
M 2003 Explorer 4.6 timing chain help Stock 2002 - 2005 Explorers 0
R Timing chain replacement cost on 2003 Ford Explorer Eddie Bauer Stock 2002 - 2005 Explorers 2
D 2003 Ford Explorer 4.0L engine. Timing chain replacement. Stock 2002 - 2005 Explorers 8
F Steps for fixing the timing chain !!! 2003 Stock 2002 - 2005 Explorers 1
J 2003 SOHC 4.0 timing kit repair Stock 2002 - 2005 Explorers 6
S Tool kit to replace timing chains and cassettes on 2003 explorer Stock 2002 - 2005 Explorers 3
S Setting Timing on 2003 Explorer without the Special Tools Stock 2002 - 2005 Explorers 1
H Question about timing 4.0L 2003 Ford Explorer Flex Stock 2002 - 2005 Explorers 2
O 2003 4.0L Cam Timing Stock 2002 - 2005 Explorers 4
M 2003 4.0 ticking (not timing chains) Stock 2002 - 2005 Explorers 2
J Wanted 2003 Ford Explorer Timing Chains- what kind of pulley do I need? Stock 2002 - 2005 Explorers 8
L 2003 body mounts Stock 2002 - 2005 Explorers 1
B 2003 Mercury Mountaineer remote starter/PATS system no crank Stock 2002 - 2005 Explorers 1
F Need Advice about Getting Replacement Tires for 2003 Explorer XLT Stock 2002 - 2005 Explorers 3
M 2003 fender flares Stock 2002 - 2005 Explorers 2
0 2003 XLT Front metallic "popping" noise. Stock 2002 - 2005 Explorers 5
mfitz725 Programming Problem 2nd keyless entry fob 2003 EB Stock 2002 - 2005 Explorers 1
M 2003 Hard Shift into Reverse after warm Stock 2002 - 2005 Explorers 5
P A/C blows warm air at idle 2003 Stock 2002 - 2005 Explorers 3
0 Rear Ball Joints 2003 16" Wheels Stock 2002 - 2005 Explorers 4
R 2003 4.0 V6 bucks driving Stock 2002 - 2005 Explorers 1
I 2003 4.0L pushes antifreeze out of the bottle when I start it. Stock 2002 - 2005 Explorers 1
W 2003 xlt 4.0l v6 advice on gasket kits/jobs to do Stock 2002 - 2005 Explorers 2
M 2003 4.0 XLT exploder lockers? Stock 2002 - 2005 Explorers 1
E 5r55s 2003 explorer year interchange Stock 2002 - 2005 Explorers 1
S 2003 Ford explorer xlt quarter window glass Stock 2002 - 2005 Explorers 0
S 2003 ford explorer charing issue fusable link replacement? Stock 2002 - 2005 Explorers 1
Swinson1974 2003 NBX... I need some opinions. Stock 2002 - 2005 Explorers 2
G OEM electric fan on 2003 explorer sport Stock 2002 - 2005 Explorers 1
C 2003 Engine Swap To 2005 Ford Explorer Swap Stock 2002 - 2005 Explorers 5
S Hi im shawn trying to figure out the rumbling sound from breather box 2003 ford explorer xlt Stock 2002 - 2005 Explorers 2
W 2003 Ford explorer misfire Stock 2002 - 2005 Explorers 1
0 2003 4.0 Spark Plugs Stock 2002 - 2005 Explorers 5
P 2003 Ford Explorer auto trans Stock 2002 - 2005 Explorers 2
G 2003 5r55e 4wd modifications Stock 2002 - 2005 Explorers 0
F 2003 explorer won’t start Stock 2002 - 2005 Explorers 4
G 2003 Explorer sport 2dr 4wd Leaf spring Stock 2002 - 2005 Explorers 3
A Advice on Transmission, possible failure - 2003 Explorer 4.6 L V8 Stock 2002 - 2005 Explorers 12
J 2003 ford explorer xlt windows not working Stock 2002 - 2005 Explorers 4
Swinson1974 5R55W Issues..... 2003 XLT/NBX 4.0 SOHC. Stock 2002 - 2005 Explorers 5
M Is there a market for a 2003 Explorer? Stock 2002 - 2005 Explorers 3
2 Please Help - 2003 Ford Explorer Won't Start Stock 2002 - 2005 Explorers 5
D 2003 Explorer Eddie Bauer Aftermarket parts Stock 2002 - 2005 Explorers 1
0 2003 Explorer XLT V6 Rear End Stock 2002 - 2005 Explorers 4
T 2003 Odd cooling issue Stock 2002 - 2005 Explorers 5
Similar threads
