ziob
- April 23, 2013
- 2004 ford explorer
hi all,
have an 04 explorer 4.0 v6 thats been sucking coolant from the reservoir. can't find any stains or obvious leaks....no puddles under car...no bad hoses, nothing on thermostat housing basically clean as a whistle not even a little wet anywhere. Mechanic shop did pressure test, cylinder test checked plugs nothing in oil that would mean bad head gasket. Any ideas on anything else to check? not even a decent smoke or smell from exhaust its going somewhere but nobody can figure it out.
any ideas?
Also has anyone used some sort of stop leak that is good enough but won't clog the crap out of everything.....i remember they made a bronze powder that worked and wasn't that silicate stuff that gums up everything.
any ideas?
