tcarney57
- December 14, 2021
- Portland
- 2005 Explorer XLS 4x4
My 2005 V6 flex 4WD Explorer is throwing a Check Charging System message on the dashboard. Fully-charged (separate charger) battery reads 12.4V. So does the main B+ post on the alternator. With engine running the battery reads 11.2V. I'm trying to verify wiring, fuses, fusible links before replacing alternator.
The Haynes manual diagram does not seem to match my alternator. It (my alternator) has the main B+ post, a separate blade-type connection nearby with a ~12-gauge white/black wire, and a three-wire connector on the right-hand side. I am assuming the separate black/white wire near the B+ is the alternator field wire, and that it ought to read the same as the battery voltage with the engine off. Instead, it reads 0V (not even any random millivolts--as if it were grounded). Is my assumption correct, and that there's something wrong with the field wire connection back to the battery?
Thanks,
Todd
Thanks,
Todd
