John Edward M
- March 5, 2019
- Slidell
- 2005 Ford Sport Trac XLT
After replacing old engine because of blown head gasket, the transmission is not operating? Prior to the engine problems the transmission was good. I have checked everything the fluid is at proper level and there are no transmission codes? When i place it in gear it will only engage when i rev the engine and then only in one gear? When I put it in reverse it will engage forward and not reverse? I am in the process of replacing the transmission range sensor? Has anyone else had this problem? John
