touchmenot24
- January 27, 2019
- San Jose
- 2005 Sport Trac XLT
Hey everyone! My sport trac started having this problem for a few months now. I noticed that this only happens when the engine is still cold. I'll let the engine run for about a minute or so, put it on drive and sometimes it feels like it's still in neutral, press on accelerator and it won't go for a couple seconds, and then suddenly lurch(shudder) forward.
Sometimes it engages smoothly from park, I turn two corners and suddenly I feel like I slipped in neutral again(foot on gas and I'm not going any faster despite the RPM going higher on the tachometer), then a couple seconds later; I lurch forward again. Has anyone experienced this issue?
My truck did start leaking transmission fluid, so the reason might be that my transmission fluid level is low. I fill it up a little every week, but I find it hard to properly do so cause I can't accurately check the levels using the dip stick and I really don't want to end up overfilling the transmission fluid. I plan to drop the pan, change the filter, replace the gasket(which I presume is the cause of the leak), and refill the transmission fluid.
I tried searching on this forum, but I can't seem to find the right transmission filter for my truck. All I can find is for the 4WD, I have a 2005 Ford explorer Sport Trac XLT 2WD V6 SOHC Auto-trans. Does anyone have a link or a part number?
Picture of leak:
Picture of leak:
