jmreynol01
- June 18, 2010
- Lexington, KY
- 2006 Explorer XLT 4WD V6
My 2006 Explorer started vibrating when I applied the brakes at about 40K which I have assumed was caused by warped rotors. I now have 60k and this thing really shakes if you hit the brakes on a long trip at 70mph. I took the truck to the dealer and they said that all four rotors are warped so of course they suggested they do the work. They have been reliable in the past but they want $750 dollars for parts and labor (pads and rotors). I would like to do the work myself and upgrade to a set of rotors that may hold up better. I have been looking at EBC, Raysbestos, Powerslot and Centric rotors. My question is: Is there anything I need to be prepared for if I order a drilled and slotted rotor ? I don't want to buy these and then find that I need a special shim or new caliper bracket.
Thanks in advance
JMR:exp:
Thanks in advance
JMR:exp:
