oharris
- October 31, 1999
- Peyton, CO
- '96 & '98 XLT V8, '00 XLS
My daughter's boyfriend's '07 Mountaineer started acting up yesterday. First of all, what does it have? It's a V8 AWD, which trans is it? I tried to check the fluid, but couldn't find the dipstick. How is one supposed to check the fluid?
They told me it was shifting hard and when you came to a stop it felt like someone bumped you from behind. I thought maybe it was a u-joint, but after searching here it sounds more like this problem.
http://www.explorerforum.com/forums/showthread.php?t=199183
Later it stopped shifting all together so they brought it out here and borrowed my Explorer. I took it for a test drive this morning and at first it shifted fine. I stopped at the first stop sign and after that it refused to shift again. It still goes into reverse, but D-3-2-1 are all the same. Any ideas what this could be? I'm thinking maybe the valves or solenoids in the valve body are sticking. It has 114K miles on it which isn't a lot IMO. Is this common?
