absentx
- December 20, 2007
- Milwaukee
- 2010 V8 Limited
Hi All - scanned through lots of threads and done three repairs now and I can't figure this out.
2010 V8 Limited, 145,000 miles
So, started hearing a hum/whaa whaa wha type sound between 45 and 55 mph about six months ago. Reasoned my new tires needed to be rotated, so I rotated them (which put the tires at about 8000 miles). This did not help the hum, but shortly thereafter I had an ABS light which indicated failure of front drivers side sensor.
I figured "great, the hum most likely is the hub, I'll just replace the whole thing" which I did.
Hum kind of improved but ultimately not really. So last month I had no time to wrench myself so I took it in. Mechanic says " you need a new passenger side front hub" Okay sounds fine, we all know how these hubs are, so the timing and mileage was about right for both to be replaced.
Go to pick up the truck once they were done and there was a note from mechanic "change front drivers side soon!!" I talked to the mechanic and said "I replaced that one 1000 miles ago!!" and he said, "well you still have a sound/hum up on that front drivers side".
Took truck home and drove for another 1500 or so miles and sound seemed to improve for a bit, but then just seemed to be starting to make even more noise etc, so I decided to tear back into the truck yesterday.
Warrantied the Hub at O'rielleys and since there was a lot of grease I was worried about the CV so I picked up a new front driver side CV axle.
Installed both the CV and the new hub today. Tightened hub bolts to 90 foot pounds, caliper bolts to 100 foot pounds and cv axle nut to 184.
Took for a test drive. Same hum between 45 and 55. I essentially gave the thing a new driver side front end and it didn't help. Could this simply be a tire issue? Where do I look next?
Thanks!
- Step one, put rear of truck on jacks and checked each rear hub. No play, both seemed smooth and solid.
- Jack up front driver side and check the one I put on back in May. Sure enough, there was some play.
Thanks!
