2013 Ecoboost Yellow wrench on dash | Ford Explorer Forums
Dva36
Charlotte
2013 explorer turbo eco
So, my suv started a shaking like if i was going into a bumpy road, took it to get it diagnosed and ford dealership mechanic said he dis not have anyone that could drive it enough to mimic issue, went to pick up and now it is worst barely maid it home, when i could drive it.
Here if you areanything aside a white person, you will be in trouble.
Now i been looking for the purge valve solenoid and can not find it. I have this car.
welcome, sorry to hear about your issues. If you could elaborate on the "Shaking" problem, like which speeds, while turning, etc. Cold be so many things from front end to Transfer case, to transmission, etc.
Purge valve is a shut off device in case of wreck to kill fuel to engine. Thats NOT your problem
A purge valve vents the gas tank. Could be leaking vacuum.
Most are under the hood.
Would be way better to have codes read as anything's a guess. AutoZone parts store may do this free for you. Just don't let em sell you a part that is not visually damaged, without posting back in here for the experts
The turbo system does use a waste gate valve, possibly vacuum operated.
I can't believe a dealer turned you away.
I apologize Dva36, I have my valves mixed up. Turdle been around longer than me, He has great knowledge of these t
"Thangs"
"Thangs"
Not really. I'm dealing with a purge valve issue on another vehicle.
keep the ideas coming.
Welcome to the Forum. :wave:
Perhaps the following will help you locate it.
Good luck and please report back.
So i need to find the purge valve
Thank you. I really hope someone with the same vehicle as me can help me or an honest grease monkey
Driving normaly it would shave the front, where the motor goes like being in a bumpy road up and down, to it to a shop and they replaced the motor mounts and turbo, since it went bad later on this issue. That did not made any diferance, mechanics would test drive it and could never find the problem.
Did the links I posted not help?
I don't think that purge valve would cause the vehicle to shake.
To keep things simple, the first step is to purchase an OBD2 reader if you don't already have one. A decent BT dongle is about $100 well spent. From there you can download Forscan or Torque apps to your smart phone and read codes (ForScan will provide more data).
Depending on what codes you find will determine the proper troubleshooting path. These engines are very complex but easy to work on if you have the right tools.
I suspect if there are no codes it may be the harmonic balancer or driveshaft issue
welcome to EF!
Yes, and the scanner showed a leak, cant temember the name this minute. But i will update and also record where parts are for others with similar issue.
Codes p0731, 0733,0734,1780,0116,1703,B1007
