dbronson
- May 2, 2021
- Blanchard
- 2013 Explorer XLT
Recently my son purchased a 2013 Explorer and the keyless entry does not light up or do anything. Also, his battery is draining and he has determined that the amperage draw is coming from fuse #18. I am thinking it might be related but he does not want to purchase a new keypad only to find out that it is not the cause. Are there any tests that he can do to determine for sure that the keypad is causing the current draw? Can he just disconnect it and will everything else work? Should he test the wiring going to the pad to make sure it does not have a broken wire somewhere? If so what wire should he test?
Thanks for your help.
