sparty87
- April 28, 2020
- Ithaca, Michigan
- 2013 Ford Explorer - Base
I went to Oreillys and got a new caliper, rotor and brake pads since I had a seized caliper and those other parts needed to be replaced too. After replacing them there’s a almost humming sound now coming from right rear brakes and it gets very hot even after a short test drive. Also you can smell the pads as well. I took everything apart thinking it might be the clips were in wrong but now it’s doing it again. Sound stops after I get up to 20-25mph.
I’m thinking I may have gotten the wrong brake pads at Oreillys? I don’t know what else could be wrong. I put the 330mm rear rotor on so I thought it would be standard. C1377 is the part number of pads I put on. Any thoughts? It looks like in 2013 some models started using heavy duty but I’m pretty sure mine is just a base model.
