Benk016
- April 5, 2017
- Skiatook, OK
- 2015 Explorer Sport
My fusion did something similar. But once it did it, it never would start again. Dealership had to replace the backup camera. The connection between the camera and the transmission had gone bad, and the camera was causing the car to think it was in reverse, and wouldn't let it start. No errors of it not being in park or anything like that. Just acted like you weren't pushing the brake pedal to start. There was an SSM for it, but it only applied to fusions.
SSM 45366 - 2013-2014 Fusion - Intermittent No Crank No Start - DTCs P06B8, P062C, And/Or B115E - Built On Or Before 3/3/2014
Some 2013-2014 Fusions built on or before 3/3/2014 equipped with a rear parkingaid camera may exhibit a battery draw, an engine that will not crank unless thebattery is disconnected and reconnected, or an inoperative rear parking aid camera with possible DTC B115E. DTCs P06B8 and/or P062C may also be present and notclear until the battery is disconnected. This may be due to an improperly controlled PCM power relay due to water intrusion in the rear camera connector. Checkfor water intrusion at the camera connector. Leave the connector disconnected and see if the battery draw, no crank, run-on, P062C or P06B8 is resolved. If concern is resolved or moisture is found, replace the camera and install a new camera harness DS7Z-13412-B. Use applicable labor operations from Section 11 of the SLTS manual.
