2016 Limited Rear Brake Pads | Ford Explorer Forums
Joe Morris
Falconer, NY
2016 Explorer Limited
I recently changed the rear brake pads and rotors on my explorer. Got the pad and rotor package from 1A Auto. After my last oil change the dealership told me that the pads were too big for the rotors. They looked the same size as the old ones. Anyone have any suggestions or had this happen?
I believe it was part number 1ABFS02463.
Thank you. That must be their own part number as it does not match any Ford numbers.
What was their point in stating this to you? Is there any issue with the brake performance?
They said that as the pad wears down it would cup over the top of the rotor. It kind of makes sense to me but I don't see how it could be that big of a deal
That pretty much narrows it down to one of two things...wrong pads OR Wrong Rotors. IIRC all rotors and pads should be the same for front and rear with the exception of Sport which use heavier duty pads and rotors.
As of 2013 all have the same HD brakes as the Sport.
