Hello, new member. I purchased a 2016 PIU a month ago, for my son to take to college. i was told the AC didnt work. to my surprise, when i turned it on, it worked fine for a month. today it stopped working & my son leaves on Sunday. I have been reading posts & did some trouble shooting but want some advice.
to start:
the AC system is blowing warm air
the clutch is not engaging
swapped relays & still nothing
all fuses good
Relay is a square with 4 pins, if im looking at driver from front pins will be
1 2
4 3 clockwise
car off
pin 1 - 12v/ pin 2,3,4 nothing
car on ac running
pin 1 & 4 14v
pin 2 2.55 v
pin 3 nothing
jumper from pin 1 to 3 hear a small click near compressor
12 v on white pigtail at compressor when car/ac on
nothing on black pigtail at compressor
clutch spins freely when turning by hand
readings on gauges, car on or off
High side is 150 (should be 235-280)
Low side is all the way to 300 (should be 42-55)
outdoor temp is 108,
After doing all of this Im leaning towards the compressor. is there anything else i should be checking before i swap out the compressor?
thanks in advance.
