rickh925
- December 31, 2007
- Canton, GA
- 2022 Explorer Limited 4WD
I've had my 2022 Limited 2.3L 4WD for about a month now and noticed that shifting from drive to reverse is very slow. I always make this change at a dead stop with my foot on the brake pedal. What sometimes happens is I come to a stop, shift to reverse, take my foot off the brake and press the accelerator and the engine revs like it's in neutral. I check to see if it is in neutral and it's not. It can take probably 3-8 seconds sometimes to go to reverse. Once it engaged as the engine reved up and "snapped" into reverse and jumped back as I slammed down on the brake in my driveway.
This happens mostly after driving for a while like when I get home and I'm backing into the garage in a k turn to line up correctly and avoid the obstacles in the driveway.
Thoughts? I've owned 4 explorers going back to the 90s, frequently with north of 200k miles each and never had this happen.
