- February 2, 2002
- 1998 Mountaineer AWD
How many miles are on it? Most of the problems you are having are minor. When you say "bad brakes 2 sets of pads already" Do you mean 1 set in the front, and one in the rear? Clean the shift motor, lube the hatch, adjust the striker bolts a little closer to the body,get a window switch, replace your sway bar bushings, and do the brown wire mod. Tehn most of your problems will go away. The timing chain rattle your likely stuck with, but being on this website you should have known to avoid a SOHC that hadn't had the recall.
