Mikel2You
- April 8, 2006
- Omaha, Ne
- 02 XLT
The facts man...
I lost 1 fob for my 02 Explorer. I bought 2 replacements for a total of 3. I can get one programmed at a time, but not the others. Here's what happens...
I go through the programming instructions with any one of the 3 fobs and it works fine. But as soon as I try to program 2 fobs at the same time, neither of them work and the it won't come out of programming mode. I do the click back and forth 8 times, it does the confirm lock/unlock and press one button on the key fob, it confirms the programming and again when I turn off the key. It's all good with the one fob. But if I go through the same process... click back and forth press one button on the key fob, get the confirm lock/unlock and then immediately press a button on another keyfob nothing happens from then on - no lock/unlock confirm, not even turning the key off. Neither the first or second fob works. Even if I do the click back and forth and try to program the first fob again, nothing... no lock/unlock. The only way I can get the programming mode to work again is to temporarily disconnect the battery and start over.
So, no problems getting one fob programmed... I just can't get two programmed at the same time.
What is going on?? Thanks for your help!
