3 different problems with ford Explorer (Drive and steering related) | Ford Explorer Forums
Aussie Explorer
Western Australia
98 XLT
1998 Ford Explorer XLT, 5 speed Auto (4WD) 4.0Ltr S.O.H.C
1. When transmission is shifted into reverse from drive there is a clunk, also same if shifted from drive to reverse but hardly anything on that one,There is NO clunk if shifted from park or neutral to reverse or park or neutral to drive . Have checked rear drive shaft and there is no movement in it and feel’s very solid and no oil leaks. Front drive shaft has some movement in it (you can turn it, but not far) and pinion seal is leaking. Noise is defiantly from the back but. Transmission is fine and shifts smoothly.
2. When you drive down the road at any speed up to say 70kp/h or 45mp/h (above this it is to hard to distinguish between wind, tyre and road nose) you will get a whoomp whoomp type of noise not fast but, about every 2 seconds or so. It makes no difference if you are under power, coasting in gear or in neutral it is still their. It is maybe a little louder when coasting in gear; it stays at just about the same rate regardless of speed but when you get down to around 20mp/h and slower it gets a bit louder and slower, then when you put the brakes on it slows right down and gets a bit louder still. It is coming from the front (and possibly the back once brakes are applied very hard to tell).
Oh. The only time you will hear the noise is if the radio is tuned off or right down low like to the point where you can berley hear the radio. (Ford factory premium sound system).
3. The steering> Only noticed this today, When you make a sharp turn at low speed as you turn the steering wheel back to centre about every ¼ or ½ turn it seems to hit a patch of higher resistance for just a fraction of a second. Like if you let the steering wheel spin back to centre by-itself it slows just a tad evry 1/4 or 1/2 turn as if I gave it a tap with my finger to slow it then returns to normal rotation.
Do you know what would be the most likely to cause the above problems?.
I almost feel as if I am nit picking at something that is basically normal or hardly a issue. I am a Mechanical Fitter by trade but on heavy industrial Equipment, I work at a shipyard at the moment installing all the mechanical, Hydraulic and like 1000k’s of pipes and hoses, which are more than I care to remember for 190Ft and bigger boat’s so it is a little different to a Ford Explorer.
Sorry, Car is currently on 78,000 miles or 125,000 k's
You might want to check your ball joints. If they are worn out the tire might wobble slightly, thus creating the whoomp whoomp sounds you're describing. Jack up each wheel and try to push it back and forth on the top and bottom and watch for play. It would probably help to have someone watching it for you, or moving the wheel for you. If that's the case, they're not too hard to fix. Otherwise, it might be a wheel bearing, which a lot of places want to give you the whole hub assembly, but it's a lot more expensive, although a bit easier to install.
As far as your clunking with putting it into drive or revers, their is some play somewhere, but i wouldn't let it bother you too much, it could actually be just the transfer case gears or the tranny gears, or the rear diff gears. Check your fluids, maybe even swap them out for synthetics and see if it goes away some.
It's possible to replace/repack the wheel bearings without replacing the whole hub assembly? Can I ask how, or where I can find out how? I thought these were sealed units.
On a 2nd generation 95-2001 Explorer with 4WD or AWD, you have to replace the entire hub assembly.
jtsmith said:
The steering problem might be the u-joint in the steering intermediate shaft. I too had a bad one.
How hard is it to replace these?
pretty simple, There are 2 bolts, 14mm I think, one at each end. The one on the steering box end is kinda tricky to get to. If the wheels are pointing straight forward. so will the bolt head.This is really easy if you remove the driver side front tire and inner fender well. The shaft itself telescopes together to get it out of wheel well opening.
Thanks for the replies, I grabbed the front tyres and shook the **** out of them, not on stand’s but, and there was bugger all noise or play, only the water in the overflow tank and widow washer tank sloshing around+ the rubber suspension bushing’s creaking a little.
The dust cover on the steering U Joint has ripped so I got in there with some lithium spray Grease and it has not done it agene.
It is almost sound’s like a tyre noise, I have Cooper AT’s with 25000k’s on them. I can’t hear any noise when the driver window is down even when I am just rolling down the street.
I always new wheel bearing’s could be a possibility but they are Expensive as far as wheel bearing go.
