dino11
- November 19, 2009
- Princeton, ky
- 02 exploder
I have 3 electrical problems. Any info or tips or whatev on any of these issues will b appreciated.
Issue 1- passenger door lock and switch.
My passenger door locks but wont unlock eletrically. I have to push it manually. Also the switch on that door dont work. I have to replace a busted mirror on that side so i will investigate while i have the door panel off.
Issue 2- my tail lite fuse blows everytime it rains.
Number 16. I noticed a crack in my lense and am soon to try to seal it. Whats a good clear sealer? Is there sumthin like wd-40 i can put on bulbs to help keep water away?
Issue 3- no cruise control,airbag or horn
My x had the steering column replaced. Guy said just needed wires hooked up behind airbag. I didnt see any loose wires. No horn, cruise, driver airbag. Where else should i check? Airbag lite blinks also.
Thanks!
Thanks!
