Rob, I just bought the stud kit from the company who makes the SVO cover for Ford. Remember my TA cover? That's the same thing with a different name. In fact, as of yesterday I have a SVO cover, because I had some problems with my old cover. TA Performance is located in Scottsdale so I drove by and picked up a new cover and a stud kit.
Ford/Dana Stud Kit TA 1816 4 stud kit, replaces stock bolts on carrier bearing caps 19.95* whn purchased with cover, 24.95 when purchased seperately. (480) 922-6807
Tell them I sent you, I would love for those guys to advertise here
For those who are interested:
The TA Rear End Girdle is based on the Geise Girdle developed in the early 1970's. TA
Performance bought the remainder of the patent, and began to produce an improved and upgraded
version of the Girdle. After refusing to produce a less expensive, thus lower quality cover for large
parts wholesalers, TA Performance soon found that copies of their cover were being produced and
sold. Though the other covers look very similar to the TA cover, many important qualities are
different. An independent dealer that was considering which product to promote, purchased one of
each cover and performed his own tests. He placed each cover, one at a time in a hand operated
press, and pumped the jack, the "copy" cover began to flex while he was still able to pump. The TA
cover never showed any signs of flexing, even after it was impossible to pump the handle any further
and with the 200+ pound man hanging off of the pump handle. Also the fit and finish, and quality of
hardware was noted, so the TA cover sold itself. Recently TA Performance did a quick check of this,
by using an air powered press, at 10,000 PSI of pressure there was no signs of flexing. The TA cover
is also the only cover to be tested and approved by a leading auto manufacturer. Ford Motor
Company spent 2 years evaluating the TA cover and approved it for their SVO line. Yes, the SVO
cover is made by TA Performance, for Ford. TA Performance produces their own covers at their
Scottsdale, Arizona facility, utilizing CNC milling machines. The TA cover also uses specially made
hardware that meets the highest specifications, no "off-the-shelf" hardware is used, everything from the
washers to the mounting bolts to the load bolts, were designed and manufactured with the ultimate in
strength and durability factored in, for a cover that will perform every time the throttle is floored, and
everytime that the wheels bite hard or break free, you will be glad that the Ultimate bolt on support
for your rear end is silently at work. Even the gaskets are specially made, to ensure the highest sealing
capabilities and to reduce dissimilar (galvanic) metal corrosion. TA Performance produces and sells
thousands of covers annually, through a network of dealers and directly to the public, so ask your
dealer who manufactures their cover, and if they don't reply TA Performance, then you might be
buying a false sense of security. Our covers are used in applications as varied as the Motorsports
Industry itself... From Street Cars to 8 second drag cars, from weekend off road trucks to 700+ HP
Baja Trucks.
* The TA Girdles are made of 356 aircraft grade aluminum, heat treated to T6 specifications, each
cover is then stress relieved.
* The covers are machined using a 3 step CNC process, which ensures accuracy and quality.
* Each cover is hand deburred and inspected for the utmost in fit and finish. Then each cover is hand
assembled and packaged.
* All Girdles incorporate a Fill Port and a Drain Port for ease of servicing.
* All Girdles incorporate 2 load bolts with swivel "feet" for supporting the bearing caps.
* All Girdles increase fluid capacity approx. 1/2 quart.
* All Girdles show a decrease in operating temperature
* Average weight, 7 lbs
* Improves Undercarriage Appearance
