33's on 3inch body with shackle and f150coil spacers? | Ford Explorer Forums - Serious Explorations
I was just wondering if I would be able to put 33x12.50 on a 1993 explorer with a three inch body lift with the warrior shackles and the f150 coil spacers. Thanks a lot!
yes,If you have a 91-94 model.I was running 33x12.50 with just a 3" body lift.You may have to do a little trimming on the fender well.With 4" of lift you should have no problem.If you have a 95-01 you can not use this set up.
thanks a lot man!
-eric
