tgrfly
- December 26, 2011
- Muncie, IN
- '03 Ford Explorer Limited
Ok so I've searched and searched and searched some more for information on the LED bulb swap in the cluster for a few weeks now and everyone has come up with the same thing, there is ample amount of information on the swap for the 2nd Gen, but squat for the 3rd Gen. Well I'm here to tell you I have figured out the answers to all of the 3rd Gen Family's questions.
The other day I made a couple LED purchases from Oznium and SuperBrightLEDs in which I ordered LED replacement bulbs for all three dome lights, the courtesy lights, and also the license plate lights. I also ordered 6 blue 194 bulbs(DO NOT ORDER 194s/168s) for the cluster to change the illumination. Come to find out once I get the cluster out, they DO NOT fit. From Oznium I ordered 14 Prewired Surface Mount LEDs to install throughout the interior of the truck.
To take the cluster out you can just follow XtremeRanger's Moutaineer swap . Now when I completely removed the cluster instead of completely removing the shift indicator bracket and wire I just unclipped the entire indicator unit from the cluster itself. Once you have your cluster completely removed follow Xtreme's directions to complete disassemble your cluster. Now this is where this video that I found comes in handy. Now I know that this is for a Ford Mustang, BUT the 3rd Gen X cluster is built basically identical, so you follow the same process. Now I don't plan to go as far as placing red film over the odometer display, that is completely up to you.
Now here is where I answer the question about:
ANSWER: The cluster comes stock with a 286/T74 bulb installed. Now when it comes to ordering an LED replacement there are several options through SuperBrightLEDs. I will be ordering the 74-xHP3 replacement bulb in blue for my cluster. I will also be replacing the bright light indicator, cruise control, and turn signal indicator lights. All those lights I just mentioned are the same bulb, just when replacing, it's your choice of color. Your other indicators such as 4x4, check engine, theft, brake, etc. are already LED lights soldered into the gauge cluster circuit board.
DO NOT ORDER REPLACEMENT BULBS FOR 194/168! THEY WILL NOT FIT! 194/168 BULBS ARE USED IN THE 2ND GEN CLUSTERS!
As I said at the very beginning, I HAVE NOT attempted this yet, but as soon as I receive my LED replacements and I get a free day to tackle the process I will be doing so. I couldn't hold back good information to my 3rd Gen family. Once this is all said and done I will be posting pictures of the finished cluster.
NOTE: I have not attempted this yet, but will be as soon as I re-order new bulbs and get a free day to complete it.
What bulb is used in the 3rd Gen Cluster?
