4.0 sohc engine swap | Ford Explorer Forums
Deak
Iowa
97 sport 4.0l sohc
Just wondering if anoyne else was so irritated by sohc if they did an engine swap and changed over to 4.0l OHV
motor. I know it would be spendy but I am really annoyed with this engine and the lack of ford owning up to dud of a motor. If anyone has what did it cost to swap over?
Any thoughts greatly appreciated
TIA
Deak
I think it would be much simpler and cheaper to get hold of a late SOHC from a wreck and fit that. No extra changes and a better engine. No wiring or computer change.
When did they make changes to the SOHC? As far as I knew they had recalls until 2002. And even if they didn't I'm sure Ford just used a "patch job" repair. Ford isn't known for owning up to, and fixing mistakes. I'd never want a motor that had a defect so bad it needed recalled.
I love my SOHC and all the interesting noises it produces!:p
if you were gonna go to all the trouble to do an engine swap, why not go with a 5liter? why spend lots of time/money only to take a step back?
So the motor makes some noises? I have never been bothered by it, and it goes 200,000 miles proven. I wouldn't worry about it so much. Toyota uses plastic chain guides in its engines, and we all know how reliable those motors are.
I would like to see that proof in writing. Plus if this motor is so great, why is ford changing the cam guides with a program? or why if its such a great motor, are they suggesting 1200.00 worth of work on my engine?? As far as the motor swap I believe the 4.0l ohv was the same one used in the ranger? If it is that motor has plenty of power for my sport and I never intend on pulling anything. In my opinion a V8 in a sport for normal driving is a waste.
A V8 in your Ex wouldn't be a waste. The V8 and OHV motor have an almost identical fuel economy and it is a more reliable motor than the SOHC or the OHV.
Well, actually it would be extra $$$ wasted buying a trans and t-case for the v8.
What is wrong with the engine that you want to swap it?
The vast majority of the problems I have had and heard of are annoyances rather than major repairs. No the SOHC is not the best but swapping sounds extreme.
I am more worried about the tranny than the engine.:(
Maybe my expectations are a bit high for a motor. I expect a motor to last at least 100,000 miles without any major mechanical problems. If ford had not covered the front guides I would have potentially spent more then 2000.00 bucks in the last three months to fix a problem that isn't about a noise but something that can essentially ruin the motor. I would consider a swap with a newer sohc off of a 01 or an 02, but I think even these newer motors are going to develope some of the same problems just few years down the road It would just delay the inevitable.
I have been pleased with ford products in fact all my autos I have been purchased by ford. And I think there was one recall that affected whatever ford product I had at the time. this model has had 5 or 6 recalls and one program.
If I would have known about the problems the sohc has, I NEVER would have bought an X with this motor. Other than the motor I am pleased with the drive and overall comfort of the X oh forgot about the blend door, that's another 500 to fix but other than that the X has been fine oh wait there was the rusty accumluator with the feam on it that caused premature failure and 250 to fix.... I do realize that things do wear out and need to be replaced with age but at 70,000 miles this motor should have at least 30,000 miles in before a mechanic has to tear into it. If I was working more I would dump it and get a baja..... Yes perish the thought
Let the flames begin
Deak
Ford is going downhill fast. That's why, if I get another Ex it will be with the old 302 and 4r70w. It's been awhile since any major changes which is a good thing. Ford has been hurting and has been taking the cheap and easy way out which means quality and reliability is on its way out.
