Carl D.
- September 28, 2001
- St Charles MO
- 92 Explorer Sport
Recently I changed my Oil replacing the regular 10W-30 Valvoline Oil with 10W-30 Valvoline Durablend Oil. I emmediatley noticed a Chattering noise coming from the engine after the oil was changed. Took my X to my Mechanic who said that the chatter was Timing Chain Chatter which was caused by the use of sythectic oil in the 4.0.
My mechanic stated that the 4.0 are prone to engine problems when synthetic oils are used, do to there super thin viscosity which, in this case, affected the tensioner for the timing chain.
The engine in my X is new with only 8000 miles and was running perfect before the oil change, even averaging about 275-280 miles per tank with all my mods.
Has anyone else had this problem with the synthetic oils.
