ARC95
- July 16, 2023
- WI
- 2010 Ford 4.0L SOHC Sport
Hey everyone and thanks for having me,
Been browsing the forums and hoping someone could help me on this. Bought a 2010 4.0L explorer last month, and have recently been having problems with the temp gauge spiking on the higher side when driving, especially so when I have the A/C on. If I turn the A/C off, and turn heat on high it drops the temp down immediately to the center of the gauge. Bought a bluetooth OBD2 scanner that connects to my phone and saw temps as high as 230 F. Thought it could maybe be a stuck thermostat so I ordered a motorcraft one along with a simmonsautosportz aluminum housing, both of which I just replaced today. Went for a test drive around town and the same thing is still happening, driving with A/C on and after several minutes of driving my temp gauge starts to climb. We put in new coolant and made sure to have it run and fill it over the course of 20-30 minutes or so to make sure we didn't get any bubbles, before driving. What do you think it could be? Fan clutch, water pump, radiator cap? Any thoughts or experiences with the same problems would be appreciated! Another thing I will note is after the drive I looked under the front and did see some coolant dripping off the frame. I think it's from when we were filling as several times while filling we did overfill and spill some. After wiping it off and watching I didn't see any new coolant starting to pool on the underside.
Also engine has 99k on it.
