94Eddie
- September 18, 2003
- 2010 Mountaineer Premier
I would recommend changing the upper and lower hoses and thermostat if they are original.Bit of an update, if anyone is interested. I went ahead and bought some rad flush and distilled water, about 10 gallons, along with new coolant. Was going to do the flush one day and saw a pretty consistent leak under the truck. Upon further inspection I saw a steady drip coming from what I now know is the water pump. Whether it's from the weep hole, or a failed seal I'm not sure, but after doing some digging it makes sense it would be a water pump problem. The area below it and is CAKED in black sludge, a combination of coolant and dirt I'm sure. So I'm going to be ordering a new water pump, and fan clutch and doing it myself along with some help from my dad. Of course, I'll also get a new belt while I'm in there. Wanted to see if anyone recommended changing anything else while I'm doing all this. I'll still do a flush, but after I have the new pump in, to make sure the radiator is all good. Fingers crossed I'll have no more problems after this!![]()
