bajaman19
- April 1, 2012
- Lorain, OH
- 1999 Ford Explorer Sport
Hi everyone. Im sorta new on here, I was on a while ago but lost my password and username. I just got it back up today. I just had a few quick questions about a 4.0L OHV engine im rebuilding. Ive done a little research on what to get to do the swap. I currently have a 99 Explorer Sport with the 4.0L SOHC engine. Im rebuilding an OHV engine out of a 95 explorer with only 110K miles on it with aftermarket pistons, rods, cam, pushrods, valves and valve springs(if I need them) and headers. I also want to get the engine bored .030 over and get head work done. Im rebuilding it because I believe the OHV models are more reliable than the SOHC models. I have the 5R55E trans with the auto 4x4 system, not sure about the transfer case model though. All I know about the t-case is that its a Borg-Warner t-case that is chain driven. I also have factory LSD with 4.10 gears. I go to an automotive tech school so I can get a little help with some things regarding this engine swap. But I figured the forum would help me the most. I have wiring diagrams for both engines to compare them to hopefully make this swap easier. I know that an OHV engine would bolt right up to my trans. I have also read a few other articles saying I will need an OHV ecm because of the difference between the fuel injection systems on the two different engines. Im assuming those are the two major things to be concerned about. Im pretty much rebuilding the entire engine including new sensors, egr valve and tube, and all OE parts such as water pump power steering pump pulleys and belt, and anything else it needs But if there are any other major concerns I would greatly appreciate any posts on this thread.
