Hitchhikingmike
- January 21, 2008
- Dallas, Texas
- '02 XLS
Yes you read that right, I am interested in converting my 2x4 '02 explorer to a 4x4 vehicle. Yes I certainly understand how such an over whelming project this would be and how economically its is not logical compared to just trading it in for a 4x4 explorer. However I would just like to at least entertaining the idea of doing so, as I may do this one day soon.
My explorer is a 2002, 4.0L, automatic XLS.
One of my questions is what parts would I need to take part in this conversion? Is my list correct of parts needed?
I have a few more questions, I have no idea how the electronics of the transfer case would be controlled. Would I also have to purchase another computer to control the transfer case with the dash switch? Or can i just wire it into my existing computer?
I have no idea how the electrical motor on the transfer case would be controlled, the dash switch doesn't hook directly up to the t-case does it?
I know that in 4x4 mode the abs brakes would also have to be disabled, is this disabling system part of the transfer case electrical system?
Can the explorer's current computer already be used to just plug in the transfer case and dash switch to start using the 4x4 system?
Thanks
- transfer case
- front left and right drive shaft
- front differential with maching gearing to back differential
- front drive shaft
- shorter rear drive shaft to accomodate t-case
- front wheel locking hubs
- shorter transmission output shaft to accomodate t-case
- transmission rear housing to bolt on t-case
- 4x4 dash switch
- skid plates
Thanks
