MrQ's 4x2 to 4x4 Conversion w/ Auto tranny PICS
Ok, I have finally decided to make the jump and do the conversion. I found a parts vehicle at the local pick-a-part and have ran the numbers.
The parts vehicle is a auto 4x4 with coil overs and a SOA already done with 3.73 limited slip rear. Apparently it was originally owned by some suspension company.
This is how the parts and numbers are running:
_______________________________________________
Parts needed for conversion to a 3.73 4x4
-Front drive shaft -$25
-4x4 rear drive shaft - $25
-T-case skid plates - ?
-4x4 speedometer cable - ?
-Rear Axle matching front gears - $200
--Complete front axle assembly- $200
--4x4 brake rotors
--4x4 steering linkages
--4x4 radius arms
--Manual Hubs - $50
--Coils
--Transfer case - $170
--A4LD Transmission Extension - $25
-Manual Shift Linkage for TC - ??
--Replace w/ 4x4 A4LD - $75
I am estimating about $900 to do it...one step at a time. I will be pulling the front differential and coils next week.
If you have any advice I would more than appreciate it. Also if you have any of these parts for sale here and cheaper I would appreciate a heads up
Total Spent So Far = $445
--4x4 brake rotors
--4x4 radius arms
--Manual Hubs - $50
--Coils
