tybogit
- October 18, 2014
- Fairfield, OH
- 04 explorer xlt 4.0
my 4x4 light started blinking recently... I was curious if anyone was to know what could be the cause of it? I believe it blinks about 7 times. The light stays on for a second then goes off for about a second, 7 times...My 4wd still engages and works. I noticed my front end, sort of bind up and pop when I turn the wheel while moving. More likely to happen the tighter the turn. and my ball joints on the upper control arm were shot. I had the ball joints replaced and the dealer said my auto 4wd was kicking on possibly bc of uneven treadwear on my tires, (due to needing an alignment) causing the binding and popping I was hearing. But I didnt notice the 4x4 light blinking until recently.. I don't know if any of what I shared is relevant but I would appreciate any help leading to information as to why my 4x4 light is blinking and also would like to know if you guys think the dealer its correct about the binding and popping in the front end or if it is a more serious matter...
Thank you,
TYLER
Thank you,
TYLER
