If you clean the harmonic balancer off real well you will see some timing marks. They line up with a pointer on the crank sensor
Remove the spark plugs to free the compression, turn engine by hand while a helper holds their thumb on the
#1 spark plug hole, trying to plug it off.
While you are turning the engine, at some point you will hear air spray out around the helpers thumb. This should be the compression cycle. Now refer to the pointer and rotate the engine until it lines up on 0. You can also slide a long pencil into the spark plug hole and slowly move engine back and forth until the pencil is sticking out most, on the compression stroke.
Once there, stick the tool on the snsor drive unit, and drop it in keeping the tool in place. Try to keep the connector plug facing forward.
You may need to remove the tool to get the oil pump drive shaft to cooperate. That's ok, just get the synch unit in, then rotate it until the tool goes back on again. as long as the connector part is within 7-5 o:clock, all should be fine.
