5.5 inch superlift questions | Ford Explorer Forums
iroczddp
dallas, Tx
91 eddie bauer 4X4
hey guys i got a question here... i am installing my lift and just happened to notice that there are some extra parts..... ie nuts and bolts... but no place 2 put them? so what is up with that? just asking because i am confused... and the directions SUCK... but its in and i can drive it.. i know where a few bolts go but havent drilled out the holes on the superrunner brackes yet... well not all of the holes.... but other than that i am stumped... if there is anyone in the dallas area that has this kit i would like to see theres.... and just see what i am doing wrong :)only thing i was thinkin of was that i got a super runner kit so some bolts might not be used ya know... so please help me out... :) thanks
I think you are correct with you thinking. Just check and recheck and if you have all the holes filled, then you are golden.
I just did same lift... yup xtra bolts, nuts and washers all over the place .... course that may xplain why my truck is rattilin so bad... lmao jkjk
Well I know that when we did my buddies lift several bolts were to be re used but instead we went and got hardened bolts, nuts and washers.
I only wish I was the one that put the 5.5" superlift on my Ex originally cause I would not have welded all the brackets onto the frame for added protection.
It is gonna suck to grind all that off when the solid axle goes in.
